Valve body solenoid voltage
Old Apr 16, 2016 | 08:30 PM
Bcrary3's Avatar
Default Valve body solenoid voltage
So, I am curious, today I hooked my car up to a scanner to check trans oil pressure and other trans info, well I noticed the voltage on the solenoids was all over the place, I am curious to know what they should be at to work properly?
Are they all located in the lower forward valve body? Could this have anything to do with the PRV issues these cars experience?
Thanks guys!
Old Apr 17, 2016 | 07:57 AM
Highhorse's Avatar
Wow, getting kinda deep, perhaps Plums, Don or another more knowledgeable member can better answer (I hope so)?
But this... http://www.jagrepair.com/images/Auto...ansmission.pdf ...and http://www.jagrepair.com/images/Auto...P2400.PDF...is all I found and it doesn't have readout specs. I would say if it was an issue you would be throwing a DTC to reference as in the second link.
Old Apr 22, 2016 | 02:44 AM
JagV8's Avatar
I don't know about these specific solenoids but some are PWM and in case these are how were you measuring voltage?
Dudes08
176
Apr 19, 2016 11:23 AM
uncheel
Apr 19, 2016 10:31 AM
DJS
Apr 12, 2016 01:21 PM
avos
Apr 12, 2016 05:01 AM
Lagonia
Apr 10, 2016 04:58 PM
