Valve cover gasket ... Again
Old Aug 22, 2012 | 06:09 AM
Shuamanator's Avatar
Post Oil the gaskets?
Very recently, I replaced leaking cam covers for the second time. I made sure everything was pristinely clean. I used aftermarket euro seals and bolt gaskets. Used an inch pd torque wrench to make sure they no more than 89inch lbs. Plums, you suggested to oil the bottom of the gaskets, which I'm pretty sure I used a little vasoline on my second attempt. Do you suggest anything else? I also read where Felpro are better so that's what I'm going with this time and they do look a little better to me.
I really appreciate all your thoughts as I'm beginning to feel like I'm doing the same thing over and over again, expecting different results.
Shuamanator
Old Aug 22, 2012 | 09:50 AM
Thanks again
Old Sep 28, 2012 | 06:25 AM
OldMike's Avatar
The mediafire link doesn't work -- says the file was removed for some violation.
Is there a how-to that shows me how to replace the valve cover gaskets, etc.?
Thanks.
Old Dec 14, 2012 | 11:05 AM
carlgerken's Avatar
Default spark plugs
What are the best spark plugs to put in my 2001 supercharged xjr?
Old Dec 14, 2012 | 09:05 PM
sparkenzap's Avatar
Just a friendly suggestion... Why not either look in the archives or start a new thread with xjr and sparkplug recommendation in the thread title. You will get better response that way. Oh, and welcome to the forum, I am sure you will get the info you need if you ask the right way.
1964Daimler
Sep 9, 2015 11:20 AM
Bones
Sep 8, 2015 08:34 PM
jaggermang
Sep 8, 2015 07:07 PM
philwarner
Sep 6, 2015 11:10 PM
Wes Steenrod
Sep 6, 2015 06:52 PM
