Valve Cover Gasket Replacement - Need How To
Old May 3, 2014 | 07:45 AM
BW_Hunter's Avatar
I did this 2 weekends ago. I bought the Victor Rienz gasket kit and it was complete except for the VVT solenoid seals which I also ordered...Rock Auto had everything.
I was replacing the gaskets for two reasons. 1) I just bought the car and was poking to address everything and there was a tiny oil leak in one of the covers, and 2) I wanted a look at the tensioners.
So, after pulling the covers, which is very easy and straight forward, I noted plastic tensioners....they looked like the Gen 1 version. They looked fine frm the view I had but I heard statements that you really can't be sure unless you can see the other side. I trundled off to the Ford store and bought new tensioners and bolts. Using the zip tie method..which was even easier than taking the covers off, I had the passenger side tensioner off and it was cracked on the face side. Popped in the new one and went to the drivers side. That one came out in two pieces...I suspect I was minutes from destruction! Popped in the new tensioners and buttoned it up and it ran perfectly. After two oil changes....yes, I wasted 14 quarts of oil...to try and get whatever pieces were trapped n the oil, I drove the car on vacation. A total of 2500 miles later and it shows no signs of anything untoward. I'm feeing lucky that I found it before it found me! Moral of the story: when you pull the cam covers, look closely at those tensioners. if they're plastic, just go to the store and get new ones...don't even think of taking a short cut. Mine is a 2001 and while it probably came with the plastic ones, I would have thought them changed out by now.
Old May 3, 2014 | 12:04 PM
bigcat777's Avatar
Yep. Doing mine today
Old May 3, 2014 | 09:26 PM
RSpi's Avatar
Well, I did it but had a mishap with a coolant line that goes to the top of the radiator on US drivers side. I bumped it pulling one of the cover bolts out and the darn thing just snapped off. No local shop has it and the ******* is closed until Monday. I sure hope they sell me the connector that broke instead of the entire line.
Old May 3, 2014 | 10:03 PM
jimlombardi's Avatar
I have replaced these plastic lines at least 3 times over the last 5 years (line just break up when I try to remove it from clips on valve cover).
Here is a photo I found on the internet that apparently frustrated jaguar owner replaced 2 of the plastic lines with hoses (click on image to enlarge it):
Valve Cover Gasket Replacement - Need How To-photo-replacing-plastic-coolant-lines-hoses.jpg
I bought 2 of these lines the last time (used 1 and have the other as a spare, just in case I need it).
The last one I purchase was from Hampton Automotive (on Ebay) for $39.35 (coolant bleeder plastic line - part# MNC4582AC ).
Price now is $37.74 with free shipping (from Columbia SC)
http://www.ebay.com/itm/JAGUAR-OEM-M...9e3611&vxp=mtr
Jim Lombardi
Old May 4, 2014 | 08:25 AM
RSpi's Avatar
Hell, I mean heck, I think I have enough hose to make the run, and the clamps. If it were mine, I would probably have done that already. I seen them on FCP's site early this morning for about the same price.
Thanks for the info. I was a little afraid to break the tip off the radiator. God knows that I can't afford that.
Old May 4, 2014 | 11:16 PM
RSpi's Avatar
Here is my video of the process if anyone wants to watch.
Old Jul 10, 2014 | 09:47 AM
davemellor's Avatar
Many thanks to all for the great advice on XK8 valve covers and tensioners. In the middle of my project I now have a question : On the gaskets (bought from Jaguar dealer) there is a flat pad area which requires a dab of sealant, but right at the back of these pads there are two molded on rubber bits which do not want to fit into the groove on the cover. Has anyone run into this? It looks like I should carefully cut them off?
davem99
Old Jul 11, 2014 | 05:10 AM
  #28
Sean B's Avatar
davem99
can you post a pic, don't cut anything yet...
Old Jul 12, 2014 | 08:00 AM
davemellor's Avatar
Default valve cover gasket
SeanB thanks for the reply,
Attached photo, I think I did it right but cannot see the image on the post
davem99
Old Jul 14, 2014 | 02:38 PM
  #30
davemellor's Avatar
I attached a photo to a new reply, what do you think? Thanks much.
Old Jul 19, 2014 | 06:49 AM
  #31
Sean B's Avatar
Sorry haven't been on the forum a few days Dave - it looks like the seal tabs are for a spot of loctite ultra grey to keep it in place.
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
