VDP grill on XJR
Old Feb 19, 2016 | 04:48 AM
PC210's Avatar
Default VDP grill on XJR
Hi all,
I found a nice Vanden Plas grill (surround) on eBay and I was wondering if I'd be able to do a simple swap between this and the current body colored XJR grill.
Would I be able to keep the mesh inserts?
Please share your inputs and experiences.
Many thanks
Old Feb 19, 2016 | 06:20 AM
ericjansen's Avatar
Yes, as long as you are sure it is a x308 grill, and not the slightly different x300, everything is "plug and play".
The mesh inserts have 2 pins, and 2 screws for mounting, the chrome inserts click in.
Note the VDP grill has notches in the upper part, where normal XJ8 grills are smooth.
Not everyone's taste.
Old Feb 19, 2016 | 06:34 AM
PC210's Avatar
Thanks! Just ordered it, hoping for a relatively painless install.
I personally like the ribbed top over the smooth non Vanden Plas grill.
Thanks again for your help.
Old Feb 19, 2016 | 06:36 AM
PC210's Avatar
Oh no, can I swap my old growler onto the new grill? Or do I need to buy another?
Old Feb 19, 2016 | 07:35 AM
MrTeaser's Avatar
looking forward to seeing your finial results ...
Old Feb 19, 2016 | 04:19 PM
smtguy's Avatar
The growler was stuck on with double stick tape at the factory - It should come off fairly easily - mine did.
Old Feb 21, 2016 | 01:29 AM
PC210's Avatar
Thanks for that, saved me $30!!
Old Feb 21, 2016 | 01:34 AM
plums's Avatar
If you remove the growler from a painted XJR grille
what is left underneath?
Clean painted surface and no holes?
Old Feb 21, 2016 | 06:12 AM
PC210's Avatar
I've gotta buy this guy a drink
I looked really closely at both VEP grills and XKR grills. XJR's are stickers and have no holes. VDP's have holes for the same aesthetic piece. Interesting how minuscule a detail can be.
Found one off eBay for $32 and ordered. Should be here next Saturday, and the grill gets here next Monday.
Many thanks
Old Feb 21, 2016 | 07:33 AM
PC210's Avatar
While on the VDP flare topic, does anyone know how difficult it would be swapping the body colored XJR trunk piece for the VDP one?
Old Feb 21, 2016 | 08:29 AM
ericjansen's Avatar
Very easy, 4 bolts from the inside.
But note, the VDP is shorter, so be sure your paint under the present one is ok.
Old Feb 21, 2016 | 08:30 AM
andrew lowe's Avatar
Open the boot/trunk, remove the lining from the lid, remove the nuts/bolts that hold the moulding on.
Shut the lid and wash away x years of mud/crud etc ... wax, buff up, open lid bolt on new shinny moulding, refit linning to lid.
Shut lid buff away all the finger prints, go get a cold one and a chair, sit down and admire.
Old Feb 21, 2016 | 05:15 PM
plums's Avatar
Many thanks
That'll be gin on ice please
So I'm good to go on just pulling it off the painted grill?
Debadging was the real motive for asking.
Old Feb 21, 2016 | 11:12 PM
XJR Pilot's Avatar
Did it to my XJR. However, be very careful removing the nuts. The stud to the trim is plastic and the nuts are made of sheet metal and when backing out, can cut off the stud, or you might twist off the stud. Found out the hard way, but it looks a lot better than the body color trim, that's for sure! Found mine in the junk yard for $15.
trottier.ed
Feb 28, 2016 03:55 PM
PC210
Feb 24, 2016 02:37 PM
Paul Deary
Feb 23, 2016 05:04 AM
MrWhite
Feb 21, 2016 10:10 PM
lelledge
Feb 21, 2016 06:59 PM
