Vibration at various speeds
Old 01-20-2008, 06:27 PM
Default RE: Vibration at various speeds
The ECM does not need reset after battery install.
How long had car been sitting prior to battery?
Any noise associated with vibration?
Does steering wheel have any vibration?
Old 01-20-2008, 07:14 PM
Sounds like a bad wheel bearing. Get it looked at asap.
To check, lift front tire off ground and grab at 12 & 6 o'clock. See if you have movement back and forth, meaning push at 12 and pull
at 6 and vice versa. If moves like that definitly bearing. I wouldn't advise you to
be going no 70 miles per hour either until fixed.
Old 01-20-2008, 07:27 PM
Possibley juststarting to go bad. Bear in mind this is just
an opinion as I cannot see car.
This would not cause cel. You should go to get codes read and Let me know what is
stored. I hear autozone can do that.
Old 01-20-2008, 07:40 PM
If bearings tight possibley sticking caliper? As I said, had without seeing car.
How are tires? Brakes? Do they look ok?
Old 01-20-2008, 08:19 PM
The pull when you braked more indicates a caliper issue although I did have a J that pulled
because of the tires. Does it pull everytime you brake?
If so, rotate tires front to rear and drive again. Maybe rotate anyway and see if shaking in steering wheel changes.
Also front lower bushings are known for going bad. The ones in front arm to subframe. See if they are cracked.
Inspector
10-17-2015 12:51 PM
Poet
10-02-2015 09:00 AM
Doug S
09-30-2015 02:03 AM
Jaguar Forums Editor
Jaguar Press release
09-25-2015 11:58 AM
Quick Reply: Vibration at various speeds
