Washer problem
Old Apr 5, 2019 | 04:38 AM
Vladhound's Avatar
Default Washer problem
Jaguar X308 XJR 1999:
I have an issue with a washer. When I push the button for a short windshield washing the washer turns on (water is running) but the wiper does not move. Other wiper functions work fine.
Is it a software problem which could be re-programmed?
Old Apr 5, 2019 | 04:15 PM
avern1's Avatar
It isn't programmed, it is most likely a switch or wire problem. When you press wash it powers the pump and the wiper motor.
Old Apr 5, 2019 | 04:28 PM
Vladhound's Avatar
Hi Vern,
Thanks for your info.
Old Apr 5, 2019 | 04:52 PM
Vladhound's Avatar
Actually, I just found it in the manual. The button stops working when the display shows low level of washing liquid which is my case. The sensor in my washer tank has probably got stuck....
Old Apr 6, 2019 | 11:52 AM
avern1's Avatar
Thanks for the update.
watto700
XJ XJ12 ( X305 )
Jun 1, 2020 07:42 AM
mkinn
Jun 25, 2019 12:24 PM
jmurraywv
Feb 8, 2019 07:46 AM
MichelB
Feb 4, 2019 08:55 PM
Jose
16
Feb 3, 2019 11:15 AM
