water pump
Old Apr 14, 2008 | 06:14 PM
jag_genius's Avatar
Default RE: water pump
3 .. 8 mm bolts hole on water pump pulley crack them free then one 15mm wrench to push tensioner to remove belt.. then loosen off the water pump bolts then pulley off .. then 5 .. 8mm bolts for water pump .. knock old pump . clean and remove gasket on block.. three 8mm bolts remove thermostate cover then refit thermostate .. breather hole up then re fit 3 ... 8mm bolt re fit water pump 5 bolts.. refit pulley 3 bolts.. install belt. tighten 3 8mm bolts for water pump. hardest part is probably the belt for some people might wanna draw a picture of the way the belts go.. and then refill with 50/50 coolant. if it was pink uses pink jag flood.
Old Apr 14, 2008 | 06:51 PM
FactoryJaguarTech's Avatar
And make sure you bleed all the air out!!!
Old Apr 15, 2008 | 07:37 PM
jag_genius's Avatar
with a bleeder.. but if not may need to run with the cap off heat on then with it on, then leave the cap off over night . shud get all the air out
Old Apr 16, 2008 | 08:55 PM
The_Ikon's Avatar
I love this board! Great tech info on every task we all can do if we choose to tackle it..
Old Apr 5, 2010 | 04:20 PM
CapsLock911's Avatar
You guys are the best! - lol
I just sold my 03 X-type and got an 03 XJ Sport with 38K miles on it
Of course, 2 days into it - over heating : 0 )
Im in the middle of a new H2O pump and while I'm at it - a new T stat
The biggest bummer is the JTIS I purchased doesn't work on Windows 7
Can anyone help with that? I am working blind
Oh - by the way, when changing the H20 pump, don't break the overflow hose barb on the radiator with your elbow like I did - $21 at the dealer
As always - thanks again all
Wahooesprit
Dec 23, 2019 02:01 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
ksjaguar
Nov 3, 2015 10:14 AM
picard
Oct 12, 2015 11:56 AM
