Water Pump has Black Plastic Impeller
Old Apr 25, 2009 | 01:21 PM
Tomlite's Avatar
Default Water Pump has Black Plastic Impeller
Not as if I was looking for something to do, but I pulled the water pump out of my 2000 XJ8. It looks as new, with the black plastic impeller. With 32,500 miles on the car, should I replace it with a new unit from teh dealer, or by an aftermarket pump, or just reinstall the pump and monitor the engine sound and the temperature gauge.
Is the water pump from the XJR higher capacity?? Is it a better choice??
Should I buy an aluminum Thermostat housing and base and if so, from who.
Old Apr 25, 2009 | 02:18 PM
Brutal's Avatar
Only 1 question per post, yo exceeded the limit, we now raise your credit card % to 29% have a nice day and we apreciate your business
black impeller doesnt meen its the early faulty ones
replace the t stat housing with metal when you get a leak unless you like to change stuff before its a problem, then let me give you my address and come by i can change alot for you. Se ken at motorcars for the parts, and no the r pump has no more cap. That anything else
dsnyder586
Dec 29, 2024 07:39 PM
ccfulton
Sep 20, 2015 05:15 PM
mrplow58
Sep 9, 2015 11:27 AM
Saturbo
Sep 8, 2015 07:35 PM
deanh
Sep 6, 2015 08:20 PM
