Water pump recommendation
Old Sep 29, 2020 | 05:03 PM
aquifer's Avatar
Default Water pump recommendation
Just got my transmission shifting problem solved recently, and now the water pump went out. Fortunately, it happened just outside my driveway and wasn't catastrophic. Just leaking and making an awful racket. Anyway, the OEM Jag pumps are around $300, but others range anywhere from $25 to $100 some are remanufactured. I replaced the original plastic-impeller pump during the restoration process several years ago, with a remanufactured Beck Arnley pump with a metal impeller. I'm not sure why the pump would go out that soon, but I suppose you get what you pay for sometimes.
What are your recommendations for a good quality pump? Thank you
Old Sep 29, 2020 | 06:34 PM
Carnival Kid's Avatar
Always dangerous to recommend something, but I replaced my water pump with a new metal impeller type from Welshes ($39.00) a couple of years or more ago and it seems to have been fine.
https://www.welshent.com/Jaguar-Wate...et-P26109.aspx
Old Sep 29, 2020 | 08:34 PM
King Charles's Avatar
+1 on the Welsh unit.
Old Sep 30, 2020 | 04:33 PM
Jhartz's Avatar
I like the AC Delco pump
Old Sep 30, 2020 | 05:20 PM
Rockauto has the AC Delco for $49.79
https://www.rockauto.com/en/catalog/...ater+pump,2208
Old Jul 19, 2021 | 08:12 PM
edobernig's Avatar
Default deleted
wrong thread
Old Jul 21, 2021 | 11:42 PM
xalty's Avatar
the delco one piece has smaller ports than most other kits but it’s not a problem
the oe pump switched to two piece. you should use the paper gasket but there’s several kits with the old metal gasket that work fine.
delco one piece vs discontinued white impeller one piece
giandanielxk8
Jan 1, 2020 08:04 PM
Andreas Schmieg
Mar 18, 2018 01:51 PM
ObxjagXJ8
Apr 6, 2014 12:50 PM
Doug
Oct 29, 2012 09:55 AM
