Water temp gauge
Old May 15, 2009 | 09:27 PM
tag1000's Avatar
Default Water temp gauge
Hi,
whilst driving in city traffic my water temp gauge idles in the middle (as it should?) but on longer motorway trips its idling in the lower quart of the scale.
Therefor its pretty cold out there, as the heating doesnt blow hot air out anymore...
Is this a serious problem? What could this be?
Thanks in advance, TAG1000
btw: It's a 1999 4.0 XJ8 Sovereign.
Old May 16, 2009 | 09:44 AM
jag_genius's Avatar
sounds like the thermostate is stuck open .. or ect sensor fault.. both will give you less mpg
Old May 16, 2009 | 10:58 AM
tag1000's Avatar
Is there a way to check if the Thermostat is still alright? Or do I have to change it anyway? Thanks
Old May 16, 2009 | 11:01 AM
wazari's Avatar
Thermostats on these cars go out more than Paris Hilton in Hollywood. It's a good idea to replace the thermostats every two years as preventative maintenance. Not that expensive and an easy job.
Old May 17, 2009 | 11:39 AM
jag_genius's Avatar
I aid just change it .. You will see when you pop it out it will be open and stay open..
Mac Allan
Oct 27, 2015 04:49 AM
abonano
25
Sep 25, 2015 10:43 AM
adamn
Sep 10, 2015 09:23 AM
1100me
Sep 7, 2015 06:26 AM
Bcrary3
Sep 3, 2015 03:48 PM
