Weird parasite drain
Old Dec 9, 2025 | 09:30 PM
Parker 7's Avatar
The SLCM comes in many numbers depending on region of the world
Some have had the wrong one installed from who knows where
Note your VIN #
Xj 1998 - 2003 (from 812317 To F59525) (x308) Classic | Jaguar Land Rover Classic Parts
Old Dec 10, 2025 | 09:03 AM
clubairth1's Avatar
Community Influencer
Originally Posted by Don B
Hi clubairth1,
Where do you connect the clamp-on milliammeter and what other provisions do you make so that you can read its screen with the trunk, hood and all doors closed so the vehicle will go to sleep? It will help others to know "The Rest of the Story."
Cheers,
Don
I use the negative battery cable and I had to have a clamp with a hole large enough to handle that.
I leave the trunk open. The car will go to sleep if left alone. If not you can easily put something in the trunk latch to fool the car. Same thing with the hood. Jump the switch temporarily.
The meter I have has a lighted face and I can read it in the truck with no lights on. I also get ready by removing all the fuse box covers ahead of time so I won't bump or disturb anything while taking the measurements.
I found out about the voltage method long after I was pulling fuses and it was just so much quicker. With the number of fuses these cars have checking ALL the circuits is a big job!
Old Dec 11, 2025 | 05:30 AM
Jeroen's Avatar
Thanks everybody for all your suggestions. Next week I am going to try and test some more. I will update this thread accordingly
br Jeroen
J444G
Apr 5, 2025 05:01 PM
oliverdavid
Jan 29, 2025 11:09 AM
POD XF
Oct 15, 2024 12:32 PM
Peter 2700
17
Nov 25, 2020 10:13 AM
Craighead
Mar 8, 2015 09:31 PM
