What should boost gauge read at idle?
Old Mar 17, 2018 | 01:36 AM
poisonpill's Avatar
Default What should boost gauge read at idle?
I have a boost gauge installed to the vacuum line and I'm wondering what boost should I be seeing at idle? At total WOT I've seen in the area of 16-17psi (pulley and intake upgrade) but at idle it's in the negative 10-20 range. What does that mean and how can I best improve it? Thanks.
Old Mar 17, 2018 | 05:30 AM
ericjansen's Avatar
At idle, the boost relief valve is open, and there is no pressure from the S/C.
The Super V8 we did some while ago read some -22 at idle, and up till ~12 at full pull.
No mods on that one, and measured after fresh "everything" with gauge spliced at the S/C housing hose.
Old Mar 17, 2018 | 07:20 AM
Sean B's Avatar
Planet Soarer: Estimating Boost and Eaton Pulley Change
Old Mar 17, 2018 | 03:12 PM
grandell's Avatar
Which pulley and intake mods have you done?
Would be interested to know if boost holds steady all the way to redline, or if it starts to drop off as you overdrive the Eaton.
Old Mar 18, 2018 | 07:27 AM
greverrr's Avatar
That seems about right for vacuum, you must be running either an upper and lower pulley combo or have charger mods if your m122 is putting out 16-17psi, thats pretty healthy
Old Mar 21, 2018 | 10:44 AM
poisonpill's Avatar
Thanks for your help.
I have a Eurotoys lower pulley and recently got a 3.5" silicon intake.
Johnken
Jul 27, 2016 10:15 PM
JimC64
Nov 22, 2012 07:26 AM
nglshmn
Oct 4, 2009 06:13 PM
