What Transmission do I have?
Old Apr 3, 2008 | 09:44 AM
rodknock95's Avatar
Default What Transmission do I have?
I have a 2000 XJ8 L sedan and was wondering what the name of the transmission is? Its a five speed automatic. Thanks Blaze
Old Apr 3, 2008 | 09:54 AM
JagtechOhio's Avatar
Default RE: What Transmission do I have?
Hey Roddy,
Manufacturer: ZF
Model:5HP-24
Anybody that tells you they're bulletproof lives in a magical land with really good gun control laws. Duck and cover.
Old Apr 3, 2008 | 10:44 AM
rodknock95's Avatar
Whats involved in a tune-up on these engines? What brand Spark plugs is oem? Oil filter?
Old Apr 3, 2008 | 10:46 AM
Tomlite's Avatar
Default And what are you trying to do with it???
Ton of info available on these transmissions
Old Apr 3, 2008 | 11:06 AM
rodknock95's Avatar
Default RE: And what are you trying to do with it???
IM trying to see if I can get the transmission fluid changed and the filter. The dealership said it can be done on this one and that it is 1000.00
Im also looking at tuning up the engine, but dont know what brand plugs are oem and what exactly is involved in a tune-up on these.
Blaze
Old Apr 9, 2008 | 02:48 PM
ilovetrains's Avatar
My owners manual makes reference to NKG brand plugs.
Old Apr 9, 2008 | 06:55 PM
FactoryJaguarTech's Avatar
NGK definitly. Also, if you try other plugs, the cars seem to not run as well. They are cheap enough now from the dealer. Change the fuel filter too.
Old Apr 10, 2008 | 06:34 AM
rodknock95's Avatar
I have always beleived that the factory plugs are the best and wires too, especially when dealing with Ford stuff.
Whats the NGK number that I should use. The book says something xxxxx-11E, but my parts guy said the only one showing has the exact same number except without the E on the end.
Blaze
Old Apr 10, 2008 | 10:32 AM
ken@britishparts.com's Avatar
Spark plugs:
http://www.motorcarsltd.com/item.wws?sku=IN107595
Trans filter change will run about $250 for the gasket, o-ring, filter and 14 quarts of fluid. Do you have the machine to do the flush and fill?
Poet
Feb 7, 2025 02:18 PM
Marka
22
Sep 11, 2016 12:09 AM
dmatthewman
Sep 30, 2015 10:10 AM
Old_Doc
Sep 29, 2015 03:43 PM
