What type of Fuel do you use?
Old Nov 8, 2016 | 12:09 PM
Daim's Avatar
Originally Posted by omgimali
Good gas really does matter
I just buy the cheapest stuff...
Old Nov 8, 2016 | 12:48 PM
Samilcar's Avatar
Shell 93 octane AKI V-power Nitro+ (10% ethanol). Mainly because it's the only 93 octane available in my area, and it's also usually a few cents cheaper than the other stations 91 octane gas.
Old Nov 8, 2016 | 12:59 PM
omgimali's Avatar
Atleast youre buying fuel, thats what matters
Old Nov 8, 2016 | 01:01 PM
omgimali's Avatar
I like shell, but i use it so often and the only gas i use that i decided to change it to bp and i dont know what happen but the car just flys and doesnt have the restricted performance light that often.
omgimali's Avatar
Originally Posted by yeldogt
Yep -- WAWA rules the world around me. Mostly building super WAWA's ... they have gas .. and lots of it .. some are huge with .. even the small ones have 12 station/ pumps.
NJ had low gas tax and no "self serve" ... anybody going through always filled up. The tax went up .23 on 11/1 .. so it's going to make NJ gas less appealing. My local Shell station had to switch to Conoco -- Shell gas was alway a few cents more and with WAWA around he was loosing to much business
yep wawa sounds like walmart.
Old Nov 8, 2016 | 01:58 PM
JTsmks's Avatar
http://www.consumerreports.org/car-m...h-extra-price/
Old Nov 8, 2016 | 02:21 PM
Stu 1986's Avatar
How long till ur xj will be on the road?!
No definite time period, I'm close but not rushing now the bad weather is here.
Old Nov 8, 2016 | 04:39 PM
  #28
Count Iblis's Avatar
The US uses RON+MON /2 while Europe uses RON method.
As a rough rule- 91 octane here in the US is about 95-96 octane RON, while 93 is around 97-99 octane MON.
The nasty 86s over here are around 91 RON.
The cars were designed and tested to run with some level of ethanol. IN fact I distinctly remember doing a calibration for an X350 to use E22 for Brazil that has no precious metal wash coat on the catalytic convertors.
Although the energy content of ethanol is less its knock limit is higher- and the octane rating reflects the likelihood of knock anyway.
Old Nov 8, 2016 | 05:04 PM
omgimali's Avatar
Good luck!
Old Nov 8, 2016 | 05:07 PM
  #30
omgimali's Avatar
p.s spotted a x308 XJ8 at 1:52
Old Nov 8, 2016 | 05:56 PM
  #31
What's a 'Yogi- Eco" Person? Oh dear....
Old Nov 8, 2016 | 05:57 PM
  #32
What is a "Yogi-Eco' Person? Oh Dear...
Old Nov 8, 2016 | 05:58 PM
  #33
Mikey's Avatar
Im using shell and bp 93 octane fuel, thinking of switching to 100% gasoline with 0% ethanol 89 octane. What type of Fuel do you use?
What do you hope to gain?
Old Nov 8, 2016 | 06:05 PM
  #34
That Documentary wasn't great. Testing the power output required to attain a certain speed with different fuels doesn't tell much. If the engine is less knock limited-and has an ECU that is able to utlise the higher octane petrol- the combustion can be phased more efficiently. This will lead to lower exhaust temps.
The goon pointed to torque and expected that to change with different fuel but said power wouldn't. Power is a function of torque.
The power required to attain a certain speed wont change.
The trouble is that engines are knock limited at Wide open throttle usually, and driving at 30 mph or even 50 mph you're barely using 3-5 bar BMEP out of the 12-19 bar available at WOT and the engine is unlikely to be knock limited then.
Therefore you probably wont see a difference. However their reasoning is off.
When you tow in , say a land Rover, you WILL be using a lot of load and could conceivably burn out your exhaust valves if you run a lower octane than recommended.
I don't like documentaries that try to push pseudo science- its as bad as the Man Made Global Warming police.
Old Nov 8, 2016 | 06:07 PM
  #35
omgimali's Avatar
basically ive heard ethanol ruining youre engine or making it worse than it is, or doesnt have enough power, but i don't think it is suitable for this car
Old Nov 8, 2016 | 06:08 PM
  #36
omgimali's Avatar
Hahahahah "Man Made Global Warming police"
Old Nov 8, 2016 | 06:21 PM
  #37
Mikey's Avatar
Ah- you should have said that in the first place.
All cars built since the early 90s are fully compatible with E10. The sky-is-falling stories are either third handed conspiracy theories usually started by those trying to make a buck on snake oil.
The loss of power/mileage when using E10 vs. pure gas is 3%. Very few people would notice or be able to measure that small a change accurately.
Using lower octane fuel than the factory 91AKI is a different discussion.
Old Nov 8, 2016 | 06:27 PM
  #38
The biggest benefit of not using ethanol in fuel on cars I've found since emigrating is the storage over the winter: The ethanol infused fuel degrades and seperates and the car can have serious problems running when the fuel gets old or even starting at all. In the UK, I used to have old bangers sitting around for 5 years plus and apart from the clutch being seized to the flywheel (easily cured)- the fuel wouldn't normally cause any issues. Over here I've had all sorts of issues- especially on my motor bikes with tiny carbs.
Old Nov 8, 2016 | 06:32 PM
  #39
Mikey's Avatar
This a 'car' discussion board, not outboards or garden tools or motorcycles. Here's a peek inside my old Corvette's gas tank sitting with 2 year old E10. The horror!
Old Nov 8, 2016 | 06:36 PM
  #40
omgimali's Avatar
Thats the information i needed! thank you
