What's the Easiest way to set crankshaft on tdc ?
Old May 20, 2020 | 08:13 AM
RA110623's Avatar
Banned
Default What's the Easiest way to set crankshaft on tdc ?
Hi guys I want to change primary tensioners and chain guides . Now I know I should lock cams on both banks with the cam locking tool which is not expensive tool . Now what about the crankshaft?
Can I just put mark on the crankshaft and check piston number 1 if its on the highest point ?
What's the easiest way to set the crankshaft timing ?
thank u .
Old May 20, 2020 | 08:57 AM
motorcarman's Avatar
The Jaguar AJ V8 IS NOT TIMED AT TDC!!!!!!!!!!!!!!!!!!!!!!!
Please find and download my copy of the Jaguar Engine Training Course 168 and read through it.
bob
Old May 20, 2020 | 09:31 AM
RA110623's Avatar
Banned
bob
Thanks. That file have lot of good information. Don't get me wrong Bob Im asking about easiest way to put the crankshaft on correct position while changing that tensioners and that file looks complicated to me I'm not professional mechanic .
This is not easy to fit plug in the CPS location i don't even know where is that sensor that looks complicated. Now since my timing is okay can I just use marks by pen or its risky?
Old May 20, 2020 | 11:05 PM
nilanium's Avatar
There's at least a couple PDF's on timing chain replacement, and many threads on it. Timing tool kits are pretty cheap on ebay too (70 bucks or so last time I looked)
Here's the link for the PDF procedure from the forum's large files section that goes over the process in detail http://www.mediafire.com/file/wnuacw...ement.pdf/file
Old May 21, 2020 | 05:12 AM
RA110623's Avatar
Banned
Thanks .
cyber3d
Apr 22, 2016 01:52 AM
jindracusin
Mar 22, 2016 05:33 AM
noterman
Apr 12, 2013 08:20 PM
tg5398
Nov 14, 2010 11:03 AM
mattysta
Aug 28, 2010 08:54 PM
