where to buy master cylinder for 2000 XJR
Old Sep 24, 2013 | 05:12 PM
WaterDragon's Avatar
Default where to buy master cylinder for 2000 XJR
When I press down on the brake pedal, it slowly sinks to the floor, but I have no visible leaks around the car.
Would this likely be the master cylinder leaking internally?
If so, where is a good place to buy one for less than the crazy $600 the dealer wants. Mine is the 4 bolts from the booster to the firewall model.
Thanks in advance.
Old Sep 24, 2013 | 05:20 PM
Sean B's Avatar
bled the brakes recently?
Old Sep 24, 2013 | 05:49 PM
Yes, just bled them, re-bled them. You are correct, this was noticed after bleeding the brakes.
I just did a pad slap with akebono pads.
Is it that simple, just air still in the lines somewhere??
That does make sense. I think what may have happened was that I put the pedal to the floor and while holding, my "assistant" then tightened, instead of while the fluid was squirting out.
I'll bleed them again "properly" and see if I can get it fixed.
At least this is the cheapest possible fix.
The only problem I see is "you can't fix stupid"...
Old Sep 25, 2013 | 04:48 PM
Sean B's Avatar
no one believed me at first but it's a simple fix - I spent 3 days asking on here a few years ago.
The answer isn't a new MC you've got air in the front calipers, if they're standard, if Brembo's then that's another story.
Unbolt the caliper and hang it with the bleed nipple pointed directly up, now follow your standard pump, nip after the bubbles and the fluid runs clear.
Simple, and I expect a thanks as a new MC is $1,000+
Old Sep 25, 2013 | 05:09 PM
Jhartz's Avatar
It took a while, but wife is a pro at "pump,pump,pump, hold!" As she yells "holding!" I pop the bleeder, and we do it over and over until there is no more spitting. A bitch but beats the ^^^^ out of bad brakes or new MC. Haven't tried Sean's way (but I have a lot of sweat equity in training!).
perfectson
Nov 1, 2015 10:46 AM
KarimPA
Sep 12, 2015 08:15 AM
corysansburn
Sep 10, 2015 06:15 AM
obwoodie
Sep 3, 2015 07:45 PM
Bowman
Sep 3, 2015 03:17 PM
