Where to pry intake manifold?
Old Oct 21, 2022 | 11:13 AM
Joe Enge's Avatar
Default Where to pry intake manifold?
I’ve double checked my guides, and I’m pretty sure that I have disconnected everything, and some that I didn’t need to.
all the guides I’ve found basically say lift it or wiggle. Mine doesn’t budge.
is this a safe spot? -passenger/right side
only mention that I can find, pertaining to this model, is prying on the aluminum thermostat housing. Guess I’ll try that…
Old Oct 21, 2022 | 12:14 PM
Quadcammer's Avatar
They can get a bit stuck, but if after some good wiggling and lifting it doesn't come off, I would very much double check that you've removed all the bolts.
Old Oct 21, 2022 | 12:17 PM
Joe Enge's Avatar
I’ve got it to wiggle a teeny tiny bit, so I’ll keep at it.
I’ve got the 12 main ones out, injectors disconnected… I’ll keep at it. Maybe I’ll notice something that I missed.
thanks!
Old Oct 21, 2022 | 12:27 PM
Addicted2boost's Avatar
Under the throttle body is an aluminum elbow going to the plastic manifold. That elbow has one 8mm bolt head on each side just above the front of the transmission. Make sure those are removed. You may also have to loosen two other bolts on each side of the lower elbow bracket as it pinches that elbow into place. Other than that, it should be loose.
Old Oct 21, 2022 | 02:57 PM
Joe Enge's Avatar
It was the two bolts on the pivot point under the TB.
they sure don’t make it easy to get to.
also had to loosen the ones under the two on the bracket by TB. That’s how it started to go up.
these aren’t in either guide I’m using.
thanks!
Old Oct 21, 2022 | 03:22 PM
I means to say 10mm bolt head, not 8mm.
Hyrum Lindquist
Aug 10, 2021 04:29 AM
The_Portuguese
Feb 6, 2021 07:28 PM
James Hawkins
Jan 19, 2021 08:51 AM
felinecat
Mark V - X 420G
Jul 14, 2017 11:35 PM
rianbechtold
Nov 28, 2008 08:51 AM
