Where should this be plugged into?
Old Sep 10, 2022 | 12:52 PM
Zlobby's Avatar
Default Where should this be plugged into?
The previous owner had this plug shorted to itself. I cannot find a place where this should be plugged into. What is it bypassing by shorting it?
Old Sep 10, 2022 | 01:46 PM
xalty's Avatar
coolant level sensor
float gets stuck and you get a constant low coolant warning so this is the workaround
Old Sep 11, 2022 | 11:38 AM
RandyS's Avatar
What would you have to do to make the float functional again?
Old Sep 11, 2022 | 01:05 PM
motorcarman's Avatar
Free up the float if it is STUCK or replace the coolant reservoir if it is faulty.
Old Sep 11, 2022 | 01:07 PM
Quadcammer's Avatar
id also zip tie your throttle cable adjuster to the bracket. Could be dangerous if that pops out and you need the throttle.
RochaSDS
Jun 20, 2024 09:37 AM
XJCCAT
Feb 24, 2022 06:10 PM
Andis28
May 27, 2021 04:21 PM
Darren9090
Dec 15, 2016 08:59 PM
jkallinen
Apr 17, 2015 03:43 PM
