Will a "failing" sensor cause a failed smog check?
Old Jul 4, 2023 | 05:46 PM
MathisJag-2000's Avatar
Default Will a "failing" sensor cause a failed smog check?
I ran a test on my OBD2 on torque and received the following "Not Ok TID: $0a CID:$11". I saw somewhere else in this forum that a couple of people have received this code, and I was just more concerned will it affect a smog test. The car runs great that is the only issue I can find with no other fault code beside P1111 which from my understanding is all systems are good. I have attached the torque results.
Old Jul 5, 2023 | 03:05 AM
JagV8's Avatar
P1111 is great. DO NOT CLEAR CODES as you'll change it to P1000 - bad for smog (they don't test for P1111 or for P1000, they test the actual monitors but those codes are handy for us).
If you've no other codes & MIL is off, get a smog ASAP.
Old Jul 5, 2023 | 12:36 PM
It passed today with flying colors! So i guess no issue after all probably should figure out what's wrong with that sensor though.
MathisJag-2000
Jul 4, 2023 05:45 PM
Gearhead01
Feb 16, 2023 02:27 PM
ferrral
Aug 13, 2021 04:11 PM
Noxparadise
Apr 24, 2012 07:41 AM
deadboy1977
Dec 11, 2011 03:20 PM
