Will instrument dimmer work with LED's?
Old Jan 3, 2023 | 04:01 AM
exjay8's Avatar
Default Will instrument dimmer work with LED's?
Hello chaps...can anybody tell me if the light dimmer for the instrument pack will work with LED globe replacements?
I am at the stage where I need to replace two or three globes and am wondering if it can be replaced with LED's but I need to know if the dimmer switch will work, otherwise i will stick with the normal globes.
Old Jan 3, 2023 | 04:28 AM
Sean B's Avatar
Works for me. Not much variation, either high or low.
Old Jan 3, 2023 | 05:52 AM
exjay8's Avatar
Hello Sean...have you fitted led's? and what type?
Old Jan 3, 2023 | 07:14 AM
mayhem's Avatar
Lots of good info in this video. I opted to stick with normal light bulbs on my instrument cluster, I didn't care for the look or brightness in the video.
Old Jan 3, 2023 | 07:23 AM
exjay8's Avatar
Thanks mayhem...good info ;o)
Old Jan 3, 2023 | 12:00 PM
RandyS's Avatar
I am certain there would be less current draw from the LEDs but I am not certain what other benefit might be gleaned
from such a change-over. If brightness is the focus, the stock illumination works for me
Old Jan 3, 2023 | 06:07 PM
exjay8's Avatar
Randy and Mayhem....I'm tending to think along the same lines.
The original bulbs have lasted 24 years so, Im sure new incandescent bulbs will suffice.
The local Jaycar shop supplies them T10-3W and T5-1.5W wedges so, I think I will go that route.
As you say, I don't particularly like the over brightness of the leds....as efficient as they are and draw very little current.
I need to replace my clock witht he later black and white model instead of the 'jewel hands' type in a '98.
I have been told you only need to wedge up one side of the airbag panel over the glovebox to access
the middle panel, is that correct?
Raymienets
Nov 24, 2020 05:12 AM
cdma
Apr 25, 2018 10:08 PM
dneu
Aug 12, 2015 11:17 AM
beardedjag
Aug 15, 2014 03:33 PM
super_jag
Interior
53
Apr 3, 2011 11:25 AM
