Window Squeal in my XJR
Old Dec 9, 2012 | 12:45 AM
Ipc838's Avatar
Default Window Squeal in my XJR
Every time I roll down my driver's window in the XJR,
it makes a hideous squealing sound. On my last XJ, I
used a rag with some stuff on it to clean up the felt
and it just made the condition worse.
Any ideas? It wasn't like this when I bought it, so it
is very upsetting., none of the others do it.
Thanks in advance
Ian
Old Dec 9, 2012 | 01:47 AM
Sean B's Avatar
have you tried polishing the glass inside and out? which seal do you think it is outer or inner?
Old Dec 9, 2012 | 02:02 AM
Ipc838's Avatar
Sounds like an inner, it is high-pitched and immediate
in how it comes on... sounds like it is closer to me, so
definitely inside.
Sean, how do you mean polish, I cleaned them with
Stoner Invisible Glass cleaner, they are spotless, but
I haven't used anything like a lubricant. I thought it
might streak.
Old Dec 9, 2012 | 05:36 AM
Dinger's Avatar
Try silicone spray, it works well on sticky windows and stops the motors burning out.
Old Dec 9, 2012 | 07:36 AM
Brutal's Avatar
remove the door panel with inner seal and outer waist seals. if it stil makes noise its the window regulator rails. put 3m silicone paste on the rails usually works but the rails guides are plastic and do break cocking the window so replace if needed
99xk8guy
Sep 29, 2025 10:51 PM
Wahooesprit
Dec 23, 2019 02:01 PM
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
