Windshield
Old Jun 19, 2015 | 07:22 AM
jrb53's Avatar
Lightbulb Windshield
Hi all is there any way to polish the pits out of my windshield. after the tough winter we went through, with all the stuff they put on the roads here. I would like to try to polish it before I go through the cost of a new one. IF SO WHAT WOULD I USE thanks JRB53 2000 x308
Old Jun 19, 2015 | 07:28 AM
SteveSheldon's Avatar
I personally would never recommend polishing the windshield, or windscreen as we call it in the UK :-) because it is an integral part of the cars structure.
But if you do want to, I am sure someone here will be able to recommend a mild glass polishing compound for you.
Old Jun 20, 2015 | 05:07 AM
andrew lowe's Avatar
I just use clay bar and soapy water to clean my glass, I realise that this will not remove any pits or scratches.
Had a new windscreen fitted last year, it was not that expensive, £175 + £35 VAT.
At £210 all in, it was a lot cheaper than I was expecting.
It really does make a huge difference having a new screen.
Old Jun 20, 2015 | 03:10 PM
Daim's Avatar
That is a bargain considering Jaguar charges ~€1000 for the same job here...!
Old Jun 20, 2015 | 04:52 PM
Bloody hell, that's over £715!
Old Jun 29, 2015 | 01:31 PM
Bcrary3's Avatar
If you can get someone to install it, RockAuto sells them for around $150 U.S. I am actually thinking of replacing mine because of some weird haze that I get on there when I use the wiper when it rains or gets wet.
Old Jun 29, 2015 | 03:54 PM
Have you tried clay bar on the glass?
If you do not have any, then try white tack,( the same as blue tack, but not as sticky ) with some soapy water in a spray bottle.
Old Jun 29, 2015 | 03:59 PM
Box's Avatar
Box
Use Jaguar Screen Clean Paste (C2S1638)
Old Jun 30, 2015 | 01:13 AM
Mark SF's Avatar
Also, the wiper blade should be cleaned regularly. The rubber gets contaminated with all kinds of stuff. I just wipe it with damp soapy cloth.
Most people forget this step.
Old Jun 30, 2015 | 08:33 AM
Box's Avatar
Box
Please be aware that "pits' (small chips in the glass created by rocks) can't be polished out by paste (finishing polish) but only filled. Depending on their size and depth, you may wish to use a repair kit on those areas.
philwarner
Jan 31, 2016 09:36 AM
King Charles
Oct 16, 2015 01:25 AM
