Windshield vertical streaks
Old Jun 16, 2015 | 08:31 AM
Ronco1's Avatar
Default Windshield vertical streaks
The windshield on my 2003 XJR has strange vertical streaks which look like they are IN the glass? They can be seen clearly on a sunny day from the outside of the car. Interestingly, they can not be seen when inside the car looking out through the glass..... A pro windshield guy looked and was baffled.
Anyone seen this on your cars ? is this a peculiarity of the glass used in Jaguars ? Any replies appreciated,
Old Jun 16, 2015 | 08:38 AM
WhiteXKR's Avatar
Possibly a heated windscreen, which was an option on these cars.
Old Jun 16, 2015 | 10:09 AM
Ronco1's Avatar
Thanks !.... i never thought of that. Do you know how I can determine if the car has the heated front windscreen option ?
Old Jun 16, 2015 | 10:24 AM
WhiteXKR's Avatar
See if you have the relays. This link may help: https://www.jaguarforums.com/forum/x...uestion-94996/
Old Jun 16, 2015 | 10:27 AM
jokaboat's Avatar
The heated screen elements look like a very fine set of wires inside the screen in a zigzag pattern. I can see them from inside under some lighting conditions.
A Front windscreen heater switch is also a giveaway
Number 11
Old Jun 16, 2015 | 01:09 PM
andrew lowe's Avatar
Ronco1, you are not looking at the windscreen whilst wearing polarizing glasses are you?
These type of glasses can make the heat treatment of glass visible.
philwarner
Jan 31, 2016 09:36 AM
King Charles
Oct 16, 2015 01:25 AM
