Wiring harness swap question
Old Jun 5, 2023 | 08:29 PM
Charliegoodwin3026's Avatar
Default Wiring harness swap question
I'm looking at swapping my rear wiring harness mine doesn't work unless I apply pressure to the connector. Had two questions #1 would the swap require any coding or changes to the security system and #2 would a 98' harness work in a 03' two of the fuses are different but other than that seems to be identical
Old Jun 6, 2023 | 01:47 PM
RandyS's Avatar
In your other post it looked as if you had removed the lockover bar, ...did you ever get that back
on so it would work? Without that, the only option I thought of was to tie a few wires around the
assembled box and cinch them (or twist them) until a solid connection was achieved.
Old Jun 10, 2023 | 07:05 PM
Col. Sandurz's Avatar
If you need a rear harness and wiring. PM me. I’ve got the entire thing
Felixbobcat
42
Feb 2, 2023 05:47 PM
Xnodrk
Apr 9, 2019 03:48 PM
jal1234
Nov 11, 2018 06:20 PM
MK2
Mar 31, 2015 11:30 AM
Thermo
Nov 20, 2009 12:14 PM
