Wiring Route from Boot to Cabin ?
Old Jun 23, 2014 | 10:19 AM
OTownXJ's Avatar
Default Wiring Route from Boot to Cabin ?
Many thanks for the knowledge on this forum. Using the info found here this newbie was able to bypass the SLCM and get my brake lights working via wiring to the HMSL. However, I need to find a way to get a wire from the boot past the bulkhead so that it can connect to the HMSL (without running a wire out the window). I don't want to start drilling without direction - Suggestions ?
Old Jun 23, 2014 | 09:08 PM
motorcarman's Avatar
Someone might respond if you tell us what car you are needing info about. (MAKE, MODEL, YEAR).
There is a relay in the rear fuse relay panel on some models.
bob gauff
Old Jun 23, 2014 | 09:29 PM
grandell's Avatar
if you remove the back seat you'll see two wiring looms and channels that go up the seat back, by the c pillars, and up to the parcel shelf, and then I think through a grommet into the boot.
Back seat removal isn't necessary if you can find the grommet, but it's not hard, and will make it all very obvious
Old Jun 23, 2014 | 09:47 PM
aholbro1's Avatar
Given the similarity of the models, post #7 may be of some use to you:
https://www.jaguarforums.com/forum/x...t-cabin-68061/
Old Jun 24, 2014 | 08:22 AM
OTownXJ's Avatar
Great tips and thanks to all. Funny thing - re-wiring from the HMSL was the EASY part !
H20boy
Dec 24, 2024 03:23 PM
JWheeler
Nov 22, 2019 08:28 AM
R-Sport
Sep 18, 2015 01:44 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
