To worry, or not to worry?
Old May 22, 2020 | 12:55 PM
Z07Brandon's Avatar
Default To worry, or not to worry?
I recently changed the fuel pumps on my 2002 xjr. When I checked to see if it had fuel pressure, the valve stem on the fuel pressure schrader valve fell down somewhere between the supercharger and left side head. It didn't fall on the ground. I have looked and looked. Used a pick to try and catch it somewhere. No luck. Should I worry about the valve stem starting a fire?
Old May 22, 2020 | 01:24 PM
Carnival Kid's Avatar
I wouldn't worry about it, it is probably sitting safely in some dark crevice doing no harm.
Old May 22, 2020 | 08:22 PM
M. Stojanovic's Avatar
Yes, it is made of high temp plastic and it won't even melt. And it will not come in contact with the exhaust manifold.
Old May 22, 2020 | 09:24 PM
64etype's Avatar
The cap from my schrader valve is almost certainly in the exact same crevasse....and there it shall stay unless you happen to identify the precise location. Besides, it was difficult to remove and having it gone will make the next fuel pump change easier.
Old May 23, 2020 | 04:25 PM
Z07Brandon's Avatar
Understood. Thank you all. Enjoy your weekend!
al_roethlisberger
May 24, 2018 10:14 PM
amaezing
Sep 18, 2015 03:25 PM
Rhett
Oct 11, 2014 09:28 PM
ccfulton
Nov 21, 2012 06:13 PM
Palmero
XJ40 ( XJ81 )
Dec 21, 2011 10:43 AM
