X308
Old May 25, 2023 | 02:34 PM
Noma Auto Parts's Avatar
Former Sponsor
Default X308
We just love the look of the X308. Reach out to us if you need any parts!
Noma Auto Parts, Inc. | Wills Point, TX
eBay Store
+13607732632
Old May 25, 2023 | 02:57 PM
Charliegoodwin3026's Avatar
Is that an xjr in the back?
Old May 25, 2023 | 03:13 PM
Former Sponsor
Yes that is an XJR. It will also be disassembled. What parts do you need from it?
Old May 25, 2023 | 09:07 PM
Z07Brandon's Avatar
Any mod parts on that xjr? What year is it?
Old May 26, 2023 | 10:29 AM
57loboy's Avatar
From the XJR in the background, if it has black interior, looking for decent driver side lower seat cushion/cover. Doesn't have to be perfect, have 2" hole in mine now. Thanks!
Old May 26, 2023 | 11:01 AM
Former Sponsor
We have a nice set of complete seats for this car for sale. Here is a link
https://www.ebay.com/itm/235012009882
Old May 26, 2023 | 11:06 AM
Former Sponsor
The one out of the car that you saw in the back looks like this. It has some wrinkles. Let me know if you are interested. You can call me to discuss pricing. 360-773-2632
Old May 26, 2023 | 12:10 PM
Parker 7's Avatar
Parts to not let get away are:
Wheel speed sensors
5 spoke " Penta " wheels
XJR grill and engine ECU
Windsheild washer reservoir , gets curb damage on the very bottom
Center console lid between the front seats including folding cup holder
Headlght assemblies including connectors with some wire and bracket behind the lenses and the bulbs , used as a poor silvering / bad look upgade for the X300 inline 6 same chassis version 95 - 97
Try to label each of the 4 assembly positions as they as not the same as they fair into the curved sheet metal lines
Z07Brandon ,
You would have to specify the Mod parts as they like myself may not be aware of like oversized supercharger pully diameters.
Old May 26, 2023 | 12:16 PM
Former Sponsor
No mod parts, all stock. It is a 2000.
Old May 26, 2023 | 12:20 PM
Former Sponsor
Originally Posted by parker 7
parts to not let get away are:
Wheel speed sensors
xjr grill and engine ecu
windsheild washer reservoir
center console lid between the front seats
headlght assemblies including connectors with some wire and bracket behind the lenses and the bulbs , used as a poor silvering bad look for the x300 inline 6 some chassis version 95 - 97
are you requesting these parts or just making more of a general statement about the need for these parts?
Old May 26, 2023 | 12:44 PM
Parker 7's Avatar
Info for yourself and a 2000 is the good AJ28 engine ( Sleaved cylinder walls ) and transmission ( corrected pressure regulator bypassing to shatter / damage the A drum as it comes together
I think the AJ28 has variable cams for more performance above the AJ27 which had its problems and the AJ27 is swapped with the 28 as the customer.
You would need the engine serial # for the buyer
A mod part that comes to mind is a metal thermostat housing and other engine metal uprating away from plastic that didn't do well in service
Old May 29, 2023 | 08:36 AM
ballast's Avatar
eBay Store
+13607732632
I just bought a trunk wiring harness from this business last month using ebay. Had a good experience. They answered my questions and the harness worked perfectly.
Old May 29, 2023 | 01:50 PM
57loboy's Avatar
I'll give you a call on Tuesday - thanks!
Old May 29, 2023 | 02:54 PM
XJRfatcat's Avatar
Interested in the throttle body which I believe comes with the throttle position sensor and the pedal position sensor!
(edit- for the XJR)
Old May 31, 2023 | 03:37 PM
Former Sponsor
Thank you so much for those nice words. We are happy to help!
Old May 31, 2023 | 03:50 PM
Former Sponsor
(edit- for the XJR)
We are happy to help. Do you happen to have the part numbers for what you are looking for? Also what year are you looking for?
You can either call us at +13607732632 or check out our eBay Store.
Count Iblis
Jan 3, 2023 03:32 PM
Spud Maat
Jul 13, 2022 02:57 AM
HeyCharger
Aug 24, 2021 08:17 AM
XJ8Lou
Oct 22, 2019 06:52 PM
