X308.3.2 Iridium Spark Plugs
Old May 8, 2013 | 04:45 AM
Gippsland's Avatar
Default X308.3.2 Iridium Spark Plugs
I am sure this topic has been beaten to death somewhere here but cannot find the answer to what is the correct NGK part number for Iridium plugs for the 3.2 engine (1999) Are the 3.2 and 4litre the exact same plug?
It would seem this engine never got to the USA where these are cheaper,they have no listing for this engine.
Any-one been here before?
Old May 8, 2013 | 04:48 AM
plums's Avatar
NGK has Asia-Pacific and European specific application guides available.
Old May 9, 2013 | 11:17 PM
Gippsland's Avatar
Thanks Plums. Yes they do. First place I went. But (always a but) They suggest that PFR5G-13E is the correct standard plug but when you try to cross reference to Iridium they do not show on their website.
Hence the post,I am sure some-one must know,mainly if the 4 ltr and 3.2 take the same plug.I assume yes but would rather be exact.
Old May 9, 2013 | 11:42 PM
Gippsland's Avatar
The reply from NGK for this region was:
PFR5G-13E is a platinum plug.
We do not list an iridium option for this application.
Kind regards
Customer service.
Old May 10, 2013 | 12:16 AM
plums's Avatar
If you cross-reference the two applications in the application guide and there is a match in the platinum, then it is likely the iridium are also a match.
BTW, beyond supposedly longer life, there is no point in the iridium anyways.
If you change them at 50k or less, there really is no point in spending the money.
Old May 11, 2013 | 08:39 AM
lglamb's Avatar
Just fwiw, I think Bosch has a $3ish rebate per plug. Check on RockAuto. Find a low price, you might end up $2or3 each.
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
Poet
Oct 2, 2015 09:00 AM
42Ajd
Sep 26, 2015 07:04 PM
reb1999
Sep 26, 2015 08:41 AM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
