x308 bad starting S/C 4.0 V8 engine
Old Jun 9, 2009 | 09:09 PM
jag_genius's Avatar
get a compression or leak down test..
Old Jun 10, 2009 | 06:50 PM
jag_genius's Avatar
well if you have no oil staying on the walls.. then you wont have good compression on start up after a few cranks piston rings lub the walls to seal the chambers..
or check fuel pressure to verify the fuel part is good. battery low?
Wolfy
May 28, 2024 08:06 AM
mhamilton
67
Apr 1, 2021 03:20 PM
duecedriver
Dec 25, 2015 11:47 AM
Ozzy_UK
Sep 24, 2015 08:44 PM
robiwhan
Sep 4, 2015 10:43 AM
