X308 XJ 4.0 n/a diff ratio change
Old Mar 19, 2015 | 04:30 AM
Rado's Avatar
Default X308 XJ 4.0 n/a diff ratio change
Hi there,
I know that there are quite a few threads already covering this topic, but almost exclusively for the XJR.
I am just about to rebuild the final drive of my 98' XJ 4.0 n/a (90k miles).
This gives me the option of a ratio change, since I could get a secondhand 3.27 (from a 3.2). I followed some of the threads concerning diff-ratio-change, which seems to be an issue with the s/c cars, but no problem with the n/a (ZF 5HP24).
Does anybody have personal experience? I want to avoid buying, rebuilding and installing the 3.27 just to find out that it does not work.
Thank you for your inputs
Mark
Old Mar 20, 2015 | 02:10 AM
Rado's Avatar
Hi there,
thanks to member Moscow Leaper!
I received a message from him that he did quite a few conversions himself without any problem.
So I'll have a go! I 'll share my experience with you, but not before May I guess, since I intend to refurbish the complete rear suspension as well.
Mark
Old Mar 20, 2015 | 02:43 AM
MoscowLeaper's Avatar
I hope that soon it'll possible to change a gearing in a SC vehichles too.
As soon as forum member plums will report upon a results of researches it will be clear if it's possible too
Old Mar 20, 2015 | 04:18 AM
JgaXkr's Avatar
You should be able to swap the rear end in a non supercharged car with no modification. The transmission shift points are programmed to the diff in the car so the 1-2 shift will be quicker.
FrickenJag
Jun 16, 2025 02:15 PM
vsol
Aug 29, 2018 09:46 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
1100me
Sep 7, 2015 06:26 AM
Bowman
Sep 3, 2015 03:17 PM
