XJ308 Phone Problem
Old Feb 1, 2011 | 04:54 PM
funckyguy's Avatar
Default XJ308 Phone Problem
Hi everyone, I have a 2000 XJ8 4 litre, and have dismantled all the phone apparatus, but there is still a nasty beep on my stereo on start-up; the display says "Phone" and it interrupts my stereo. It's annoying the hell out of me. Does anyone know how I can disable this please?? Thank you, Guy
Old Feb 2, 2011 | 05:47 AM
Sean B's Avatar
have you got the handbook? I'm pretty sure there's a setting in the hi-fi to enable/disable? I'll have a look later when at home to see and post back...
Old Feb 2, 2011 | 11:49 AM
xjrguy's Avatar
Try pressing the radio "AM/FM" and "Eject" buttons at the same time, that should enter radio setup. Then press radio preset 4 and see if it won't toggle the telephone off and on. Then turn the radio off to save.
If that doesn't get it, repost.
Good luck!
Old Feb 2, 2011 | 02:50 PM
pdog2000's Avatar
wow that is awesome, thanks xjrguy, i need to go try this right away...
Old Feb 2, 2011 | 03:41 PM
QuadManiac's Avatar
If this doesn't work, unplug the connection between the phone hardware and the harness under the center console storage compartment - 4 screws removes the compartment and the 10 pin connector is directly underneath.
Old Feb 9, 2011 | 03:50 PM
funckyguy's Avatar
Good luck!
Thanks XJRGuy - it worked!!!
dragonfly777
Regional
Sep 8, 2015 01:39 PM
tberg
Sep 7, 2015 07:32 AM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
