XJ8 1999, ignition coil E primary, secondary circuit
Old Aug 16, 2011 | 03:45 PM
loblue's Avatar
Default XJ8 1999, ignition coil E primary, secondary circuit
Hi Guys, I have found out what the problems is , BUT i do not know what side of the engine the Ignition coil E is , drivers side or passager side ?? Can anyone help !!!!!!. Thanks Loblue (cathie)
Old Aug 17, 2011 | 07:00 AM
test point's Avatar
Don't know if I can remember cylinders designated by 'E' alpha designations. What is the P03xx code you are getting? Look that code up in a JAGUAR OBDII chart then there is a chart in the XK8/R forum FAQ sticky that displays the cylinder numbering.
Bcrary3
Feb 21, 2023 04:29 AM
Mugatu
22
Jun 23, 2020 01:50 PM
mhenz
Sep 14, 2015 07:47 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
Bowman
Sep 3, 2015 03:17 PM
