XJ8 crank angle fault codes...grrrr
Old Aug 5, 2016 | 06:21 AM
Bobarache's Avatar
Default XJ8 crank angle fault codes...grrrr
Hi All,
I'd like to start by saying what a fantastic forum and Jag community this is.
I'm having an issue with my 98 XJ8 3.2 V8.
Went into restricted performance mode, threw the scanner on and got P1647, P1648, P1230, P0336 & P0335.
We ordered and replaced the crank angle sensor, tried to reset the inertia switch, cleared faults with scanner and started the car. It started but idling at 1600rpm and spiking to 1800rpm with restricted performance still showing on the dash.
checked fault codes again and now have P0335 and P1111.... any idea where to look?
I disconnected the battery for 30min and rescanned.... now have 4 fault codes... P0335, P1111, P1647, P1648.
Thanks in advance
now?
Thanks in advance
Old Aug 5, 2016 | 06:55 AM
I've moved your post from the General Tech section to the model specific XJ8/XJR (X308) section for better response to your issues
As this is your first post, please stop by the new member section and post an intro - in return you will receive a warm welcome and useful tips to forum navigation
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Aug 5, 2016 | 07:44 AM
Bobarache's Avatar
Thanks Steve, I look forward to a warm welcome and some advice with my problem.
Blue_XJ8
Apr 10, 2016 06:25 PM
xjmaz
Diesel variants - All models
Mar 27, 2016 02:53 AM
Nov 20, 2006 10:55 PM
Feb 13, 2006 11:40 PM
