XJ8 gear box fault
Old Sep 17, 2015 | 08:22 PM
Dixie61's Avatar
Question XJ8 gear box fault
Hi Everybody,
I just bought my 2000 XJ8. Only had it 2 wks. Diagnostics were ran just just couple days b 4 I picked it up. No codes and clean bill of health.Few days ago, it was cool out but when I attempted to turn heat on, it blew nothing but COLD air and then I got"gear box fault" message and it went in to limp mode. I did not drive it for a day.When I cranked the next day, message was gone and everything was fine. I tried the heater again this a.m. and again COLD air, gear box fault message, and limp mode again! Does anyone have a suggestion?
Old Sep 18, 2015 | 08:21 AM
sparkenzap's Avatar
Look for archives here and at Jag-lovers for info on the heater pump. Likely the brushes have worn out. Much less likely, the valve could be stuck. A plugged heater matrix generally results in low heat, not no heat.
Old Sep 19, 2015 | 06:29 AM
JagV8's Avatar
Also check battery isn't failing as that causes a lot of weird faults.
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
cissdm
May 3, 2016 06:02 AM
arnoldmilk
Sep 3, 2015 07:42 PM
