XJ8 Intermittent no start
Old Jul 31, 2009 | 01:11 PM
1Jaguar1's Avatar
Before you change the starter relay. Take off the battery connections and clean both the terminals with a wire brush and the connections. Even if they look clean,you can get corrosion that causes a no start condition.
Old Jul 31, 2009 | 01:19 PM
JagtechOhio's Avatar
And you may want to try starting the car with an alternate key if you have one, in case this is an issue where the transponder is not reading the key you regularly use.
Old Jul 31, 2009 | 05:25 PM
bulldoze's Avatar
I've also seen the bulkhead stud at the passenger side of the engine become loose and cause that problem.
Old Aug 9, 2009 | 11:07 PM
poboyblues's Avatar
Wow Andy, scrim got you here.
Scrim, re read JagtechOhio's post about the key. In case you missed it again..........yes the key could be the problem.
Old Aug 9, 2009 | 11:17 PM
See, all I try to do is give the guy a simple step to eliminate a possible cause, and look what I get back. Starter diapers, I say change the babied starter's diapers.
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
Jaguar Forums Editor
Jaguar Press release
Sep 3, 2015 09:38 AM
XJsc-guy
Sep 2, 2015 11:43 AM
