xj8 tickover
Old Aug 20, 2015 | 04:55 AM
trucknetjack's Avatar
Question xj8 tickover
hi ,can anyone give me a guide as to what the correct tickover rpm should be on a 1998 3.2 v8 mines seems to be sitting around 650 to 700 rpm, when i raise it very slightly the vibration goes.
thanks
mark
Old Aug 20, 2015 | 05:02 AM
Daim's Avatar
650 is the correct idle.
Old Aug 20, 2015 | 02:23 PM
thanks for the reply, have since found out that at least a top end rebuild is needed to cure a compression issue, and the car is at best not worth spending best part of 2 to 3 grand to fix. so looks like it is going soon.
Old Aug 20, 2015 | 03:16 PM
Daim's Avatar
Well, your idle vibration sounds totally normal to me. Are you sure your car has some compression issues? Which cylinders? Tried some thicker oil (sounds stupid but too thinner oil will result in more blowby and therefore less compression) or are your valves leaking?
Workshops like to diagnose things the car doesn't have
My former Volvo garage decided that it was time to tell me my clutch was dead and that a new flywheel was needed. Clutch was totally fine. A screw was loose and that tightend resulted in a fix of the problem.
magmedia
Oct 8, 2015 03:28 PM
freddieg
Oct 6, 2015 11:23 AM
mat32essex
Oct 3, 2015 04:12 PM
kingdom worker
Oct 2, 2015 05:43 AM
donald ebanks
Sep 30, 2015 07:08 PM
