XJ8 Warning lights on no speedo or Rev counter
Old Sep 3, 2017 | 01:55 PM
v8pete's Avatar
Default XJ8 Warning lights on no speedo or Rev counter
Hi all, just wondering if anyone can help me out, i have a 2000 Jaguar xj8, my instrument panel has engine management light on, ABS light on, Brake warning light on, no speedo or rev counter, no mileage display, the fuel light stays on, gauge was reading nearly full but now sits on empty, no Temperature gauge. The car is also hit and miss on power when driving, sometimes it feels like its in limp mode, it wont kick down, then on the other hand it goes like a Rocket with so much power it will spin its wheels no bother on pull away, any idea's will be most welcome, i have read that the instruments can go down on these cars, would it effect power? Thanks Pete
Old Sep 3, 2017 | 02:43 PM
RJ237's Avatar
Hi Pete
I weak battery can cause many strange effects, so I would start by making sure it's fully charged and the many power and ground connections are clean and tight.
Your car is a X308 so will get more responses by posting on that forum, or maybe one of the moderators will see this and move it.
Old Sep 3, 2017 | 02:55 PM
motorcarman's Avatar
As RJ237 suggested, you need to post in the proper forum section but TSBs (that nobody reads) can help with the diagnosis.
Try this.
bob
File Type: pdf
Old Sep 3, 2017 | 04:24 PM
v8pete's Avatar
Yes i noticed its in the wrong section, i did find the pdf on the CAN failure, going to have a nose at the instruments as soon as i can, still wondering if it will throw the car into limp mode?
Old Sep 4, 2017 | 03:32 PM
Welcome to the forum Pete,
I've moved your question from X300 to X308 forum.
Old Jan 10, 2021 | 11:42 PM
Inger Vos's Avatar
Did u figure it out Pete? I’m there and no solution in sight. Just put in new instrument cluster but nothing.
harryxtype
Nov 13, 2017 09:48 AM
Captainbeaky
Dec 19, 2011 06:45 AM
stevevaus
Aug 13, 2011 02:29 PM
Fast Jag
Feb 13, 2009 06:14 AM
