XJ8L Needs a new head
Old Nov 6, 2015 | 07:25 PM
bigcash's Avatar
Default XJ8L Needs a new head
Hi guys-
I am in Dallas, Texas
I just got word from the shop that I've got a bad head on the passenger side of the engine.
This is a 4L v8.
Does anyone know of a place to get used parts for Jags anywhere near the DFW area?
-C
Old Nov 6, 2015 | 08:32 PM
motorcarman's Avatar
Originally Posted by bigcash
I've got a bad head on the passenger side of the engine.This is a 4L v8.
I guess everyone would want to know the answer to the question................
What is meant by a 'bad head'?????????
Cracked, Warped, Dropped Valve Seat, Corroded, Worn Cam Bearing Areas, Broken/Damaged???????????????????
Machine shops can repair many faults but sometimes a good used replacement is more cost effective.
Are you looking for a complete head or just the bare casting????????
There are differences between the AJ26 and the AJ27 and then more difference between Normally aspirated and Supercharged.
If you are needing a bare casting then any AJ26,27, or 28 will work.
You will need to install all your original tappet and cam components or some combination to get back to original clearance/specs.
A little more info would go a LOOOOOONG way.
bob gauff
Old Nov 7, 2015 | 09:49 AM
bigcash's Avatar
I know that the head gasket is blown.
Also, when I rotate the crank full circle, one of the valves opens and by the sound of it, stays open for a moment and then slams closed. I can hear that one.
I do not know if the head is warped. My friend, whose car t his was before he passed away was chasing some burglars that he caught when he came home one day. While chasing them, the car began to over heat, then backfire and sputter. He limped home about 3 miles and that's' when he asked for my help.
We checked timing and everything we could without actually pulling the heads. I found numerous vacuum leaks that I fixed, but with a tick when the crank is rotated once a revolution and the zero compression, throw in the overheating and I would suspect the head needs rebuilt or replaced.
Old Nov 7, 2015 | 12:33 PM
The head might have had a seat come loose. That is a common occurrence when these engine overheat.
As I stated, it would REALLY help you to find a direct replacement complete if you would fill in the MAKE MODEL YEAR of your mystery car.
Any 4.0 Jag V8 head BARE can be made to work with addition work/parts.
bob gauff
Old Nov 7, 2015 | 12:47 PM
adam699's Avatar
Car-Part.com--Used Auto Parts Market
Old Nov 7, 2015 | 03:35 PM
Jhartz's Avatar
Why not load it onto a truck and take it to Decatur, TX, unless you are going to do it yourself.
The only time I ever think how nice it would be to live near Dallas, is when the mine breaks.
HTTR! I only root for two teams: the Redskins and whomever is playing the Cowboys this week.
Old Nov 7, 2015 | 06:45 PM
I have absolutely no interest in sports but I 'get-it'!!!!!!!!
Cowboys and Indians!!!!!!!!!!!!!!!
bob gauff
Old Nov 8, 2015 | 11:11 AM
bigcash's Avatar
Cowboys and Indians ... Good one. ;op
@Bob-
I guess there is more info that I need to get. Other than it's a xj8l 4.0L v8 4door. I haven't got any more info. It's naturally aspirated, bur I do not know what 'AJ26, AJ27 orAJ28' is. Are those head casting #s?
@Jhartz- What's in Decatur?
-Thanks-
-C
Old Nov 8, 2015 | 12:49 PM
RJ237's Avatar
How about the year?
Old Nov 9, 2015 | 04:19 AM
bigcash's Avatar
Well. I guess that would be important. 1998.
Old Nov 9, 2015 | 06:30 AM
RJ237's Avatar
So it's a AJ26, unless it was replaced. Do the VVT's mount at the front of the head, or through the cam cover?
Old Nov 9, 2015 | 08:19 AM
-Thanks-
-C
Motorcarman's workshop.
Old Nov 9, 2015 | 11:56 AM
Jhartz's Avatar
I say again: if I lived in Dallas Texas, I'd take it to Bob. 50 minute truck ride from The Conony to Decatur. (thanked 1651 times in 1150 posts).
I wish I wasn't a sports fan: I hold the Redskins responsible for my high blood pressure, along with butter bacon steak bourbon red wine. Both teams sucked yesterday; Redskins more than the Cowboys.
Old Nov 9, 2015 | 05:38 PM
I just looked through the shop and remembered I have a complete 1998 AJ26 engine with a worn/knocking crank. I think #3 big end rod bearing is faulty.
The heads are OK because the customer drove the car but was annoyed by the knocking.
I ended up swapping in a used engine about 6 or 8 years ago and the old engine has been sitting in the shop corner for that long.
I guess it could be unbolted and installed without machine work. The valves and cams are already setup so it would be a straight install.
You could have a valve job done if the other head is also being machined.
I also have a 4.0 S-Type AJ28 right hand (bank 1) cylinder head with about 30,000 miles on it. That would need cam swap and valve lash adjustment.
I have a bunch of Jaguar parts hidden under piles of other parts in my shop. I often forget what I have until I look for something else and find a long lost treasure.
Let me know if you are interested in any of this.
You can send me a private message.
bob gauff
OUScooby
US Western
Aug 24, 2015 11:16 PM
Kaeghl
Aug 17, 2015 11:15 AM
Jimmy3Sticks
US Southwest
Jul 24, 2015 02:51 PM
jag79
Oct 19, 2010 09:43 PM
The "R"
Sep 5, 2009 04:36 PM
