XJR 2000 model engine oil consumption?
Old May 4, 2010 | 02:34 PM
xjr4life's Avatar
Default XJR 2000 model engine oil consumption?
hi just a querie is it normal i every 300 miles or a tank ful of petrol i go through i have to top up engine oil...
i lose about a quarter from the max mark is this normal?
i currently have mobil 1 5w 30 ESP oil in the car...
regards
Old May 4, 2010 | 11:20 PM
QuadManiac's Avatar
A quart (or liter) every 1200 miles is a bit much... back in the old days, I'd say 'oil is cheap' and not worry about it. But now with the Jag, I'd be mildly concerned.
Old May 5, 2010 | 11:38 PM
Sarc's Avatar
I use about the same over 1000 miles. The car had non-synthetic oil in it when I bought it, and I ran it for 7000 miles before changing to synthetic. I did notice it seems to use more oil once I switched to the same Mobil as you are using.....
Are your cam cover gaskets leaking ?? You can lose oil out of them and there's no puddles of oil on the floor, because the oil burns off on the exhaust :-)
Old May 6, 2010 | 09:25 AM
JimmyL's Avatar
Wink Oil Use
My car will drop down to a half quart low after a few hundred miles. If I keep topping it up it will keep burning it off. If I leave it alone it will stay at a half a quart down. So, I leave it alone. Otherwise, I'd be going through a lot of oil. Others may disagree, but I don't add until it gets down to the 'add' line.
Old May 7, 2010 | 05:35 AM
rocklandjag's Avatar
I have found exactly the same thing. The engien returns to half a quart low shortly after topping it off but it never drops below that. If I leave it alone it is fine. I have an '01 SC engine
Old May 7, 2010 | 09:59 AM
DavidB's Avatar
Same here--it's a losing battle to keep the oil level exactly at the full mark, but the level becomes very stable if I leave it somewhat below full.
TTYL
David
Old May 19, 2010 | 01:31 PM
xjr4life's Avatar
thank you all very much for this info right i will stop topping up and see how i get on if it does go under the half mark then i may top up as i heard if the oil is too low on these engines then it mess up the crankshaft etc etc
regards thank you again much appreciated great help
Old May 19, 2010 | 01:32 PM
xjr4life's Avatar
also mobil 1 esp 5w30 i heard tends to burn off real quick coz of the thiness but its very very good for the engine keeps it clean...
regards
MJ'S Jag
Nov 10, 2022 08:14 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
nelsonht
Aug 30, 2015 06:01 AM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
