XJR 2002 ticking noise help
Old Mar 2, 2017 | 02:14 PM
CHEKENG's Avatar
Question XJR 2002 ticking noise help
Please help me diagnoise this sound(link below)
2002 XJR 200,000 miles.
I bought the car <5k miles ago with the throttle only opening 40%, it was a smooth and uneventful test drive
Once the throttle was fixed I loved this car so much i bought a 2003 XJR with a seized motor, for parts $800.
The current noise started out as a a ticking around 3Krpm? but has got much worse recently, not going to drive it like this.
the noise is the same with the belt off of the supercharger.
just completed compression check with TB open
front. then added oil to each cylinder.
125/106 167/156
129/112 166/140
111/111 142/146
124/98 154/136
Im thinking of removing the valve covers next, to check cams and timing chain?
perhaps the timing chain is loose?
with the compression they way it is, should i be rebuilding the motor.
https://drive.google.com/open?id=0B_...VmMmpsZnprYUNF
thanks for any help here!
Old Mar 6, 2017 | 10:40 AM
abonano's Avatar
125/106 167/156
129/112 166/140
111/111 142/146
124/98 154/136
You can pop of the cam covers but based on those compression readings that engine is done.
Old Mar 6, 2017 | 10:55 AM
Please help me diagnoise this sound (link below)
2002 XJR 200,000 miles.......
Welcome to the forum CHEKENG,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Mar 6, 2017 | 03:39 PM
avern1's Avatar
Before just scrapping the engine, I would pull off the supercharger and intake manifold and give things a good look see. Based on the compression readings and the noise your hearing I think you have dropped a few valve seats. This is normally the consequent of overheating but it isn't unheard of a failure under normal conditions.
You can get a good head refurbish/ new head gaskets and just might be in better than new shape.
Old Mar 7, 2017 | 03:52 AM
Addicted2boost's Avatar
YUP!
I wouldn't wast your time doing anything else to that engine unless you plan a full rebuild.
Old Mar 7, 2017 | 05:25 PM
CHEKENG's Avatar
thanks for the replys! ill let ya know what I see when I start pulling things apart.
