XJR acceleration Hesitation
Old Aug 10, 2014 | 12:15 PM
jameson's Avatar
I have an obd 2 scan tool but I don't know how to see the live data.
its not throwing a code ...so how would I go about see the Fuel data ?
Old Aug 12, 2014 | 08:26 AM
JagV8's Avatar
Generally if it isn't obvious then the tool doesn't support that feature (but a look at its handbook should say).
Old Jan 3, 2016 | 07:41 PM
themechanicco's Avatar
Default What did you find out ???
I have the same thing, Runs good to 3000 rpm and stumbles to 4000 rpm then runs like new. If I increase throttle early (before 4000 rpm) it makes the acceleration worse. About half throttle seems to be the best.
I have new fuel pumps, Checked the fuel trims, fuel pressure stays up at the fuel rail through the rpm range. I runs so good and throttle response is perfect above 4000 rpm. TPS is reading correct also. No fault codes
This is a '99 XJR.
Help!
Thanks,
David
Old Jan 4, 2016 | 02:06 AM
JagV8's Avatar
May be a blocked cat (or both?). IR gun or borescope or measure back pressure at O2 hole.
xjrjag
Oct 24, 2024 03:09 PM
Forcedair1
Feb 19, 2020 01:51 PM
AtholC
Sep 9, 2015 09:07 PM
XFR_Gold
Sep 2, 2015 12:24 PM
