XJR Belt Tensioners And Idler Pulleys??
Old 08-10-2015, 06:14 PM
xjrjag's Avatar
Default XJR Belt Tensioners And Idler Pulleys??
I know there is serpentine belt tensioner by the AC Compressor / PS Pump.
I know there is a supercharger belt tensioner near the Alternator.
I BELIEVE the serpentine belt idler pulley is BEHIND the supercharger tensioner.
There is what looks to be an idler pulley by the water pump as well??
The idler pulleys is what I am unsure of. The supercharger belt has no idler, only a tensioner, correct? The serpentine idler is BEHIND the supercharger tensioner, correct? But what is the idler looking pulley near the water pump??
When I look for parts, I am not finding two different idlers...only one type of idler and then both tensioners. So a bit confused on what to buy, as I need to change my belts and one of the idlers is starting to make noise, so I want to just replace all idlers and tensioners.
Old 08-10-2015, 06:57 PM
andrew lowe's Avatar
The idlers or tensioners use the same bearings, unless the wheels are worn, you can save yourself a small fortune by going to a bearing shop and just buy the new bearings!
Obviously, if the wheels/ tensioners show signs of wear/ damage, they have to be replaced.
mrplow58
01-21-2024 05:53 AM
silkcat
04-15-2023 04:58 PM
Johncy2000
12-22-2017 04:32 PM
auburn2
12-29-2015 06:31 AM
Dickie_L_J_O
09-13-2015 07:44 AM
Quick Reply: XJR Belt Tensioners And Idler Pulleys??
