XJR brakes are a weak point
Old Dec 28, 2012 | 08:05 AM
princemarko's Avatar
Default XJR brakes are a weak point
Not sure how well the Brembo's perform, but my XJR brakes are weak and i have no confidence in them. Looking for an upgrade and found Hi Spec conversions for the XJ's, anyone have other recommendations?
Old Dec 28, 2012 | 08:06 AM
Cambo's Avatar
Talk to Sean B about Alcons
Old Dec 28, 2012 | 11:39 AM
Ipc838's Avatar
They shouldn't be weak in stock form, Stopping From
60-117ft, 70, 168ft, right on the dot for a performance
sedan. On the track mine exhibited 0 fade, when even GTRs
were sitting in a cloud of smoke. They don't feel sporty but the
performance is there.
Old Dec 28, 2012 | 12:22 PM
Red October's Avatar
The pedal feel is a bit soft on the X308's but the brakes should bite properly once they're applied hard. When I stand on my XJR's standard brakes from a high speed, they haul the car down pretty well for a big saloon.
A slightly soft brake pedal feel by design is not the same as brakes which don't work properly because there may be a fault present. Check the thick vacuum pipe to the brake servo for leaks.
Incidentally, princemarko, your other thread mentions the random engine management faults you're getting with the restricted performance mode & fault codes appearing.
Now you say that you have no confidence in your brakes-so I'm thinking that the 2 faults are related.
If you have a faulty vacuum pipe to your brake servo-or even a faulty/internally leaking brake servo-you will get poor performance from your brakes & any brake servo/connecting pipe vacuum leaks will also allow unmetered air into your engine & cause all the engine management problems you're also getting.
I think you need to check your brake servo & especially the thick connecting vacuum hose for air leaks...
Old Dec 29, 2012 | 06:11 PM
Roger77's Avatar
I have had to hit the brakes hard a couple of times due to freeway idiots, each time I either got rear ended or came very close. In my experience a well maintained XJR will stop better than most cars on the road.
Forcedair1
Sep 8, 2025 01:57 PM
motorhead69
Sep 9, 2015 10:04 AM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
