XJR Cooling Fan Operation/Failure
Old Jul 25, 2015 | 07:49 PM
Ipc838's Avatar
Default XJR Cooling Fan Operation/Failure
Hi all,
The right hand (upper) cooling fan has just stopped working. It runs on the low speed but I've just noticed that only the lower fan runs at the high speed. The upper (RH) fan just stops when they go on high speed.
It isn't causing an overheat but I need to get to the bottom of it! This week I ordered a replacement fan and replaced it, but to no success - (although this is a used fan, so I can't rule it out) . I have read many threads on the 1995 XJ cooling fan issues, but haven't had luck finding X308 ones.
Why would the upper fan stop on the high speed? Is this a fault with the harness, fuses, relays?
Thanks very much,
Ian
Old Jul 26, 2015 | 04:54 AM
test point's Avatar
There are two relays associated with the two fans. On low speed the fans run in series with each using half of the available 12 volts. On high speed each fan is fed 12 volts. It would appear that one of your relays or associated wiring has failed. The relays are located near the bottom of the radiator.
Old Jul 27, 2015 | 07:00 PM
Ipc838's Avatar
Thanks very much for the intel, Test Point!
I wasn't aware of the voltage split. I will get the relay replaced and see what happens. Hopefully it's not the harness. (At 13+yrs old, all harnesses are aging/at risk I guess?)
silkcat
Jan 18, 2025 04:29 AM
abonano
25
Sep 25, 2015 10:43 AM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
1100me
Sep 7, 2015 06:26 AM
