XJR Engine Fail Safe P01227
Old Oct 7, 2018 | 09:03 PM
nd4spdlsc's Avatar
Default XJR Engine Fail Safe P01227
I finally managed to find and replace the connector body on my X308 and the pins are now changed over to gold plated. However, I am still getting an engine fail safe warning. The throttle body is a fairly new OE part from Jag. I am hard pressed to believe it's the TB. Pulling codes I get P1000 (OBD systems readiness test not complete) and P01227 (mechanical guard circuit low input). I'm seeing the following voltage at each pin (top to bottom on the TB) with the key on and ignition off: 4.98, 4.03, 4.09, and 32.8mV. What am I missing?
Old Mar 14, 2019 | 08:08 PM
nd4spdlsc's Avatar
Update: The issue was traced back to a bad ECM.
davidshuff
Sep 28, 2021 03:56 PM
Terryconn
Sep 25, 2017 04:34 AM
Vadimqa
Jul 29, 2016 09:24 AM
mrhayat
Jun 26, 2008 07:09 PM
Aug 5, 2005 11:01 PM
