XJR Engine Failsafe Mode issue
Old Apr 1, 2012 | 08:26 AM
ndrush's Avatar
Default XJR Engine Failsafe Mode issue
I have a 2003 XJR with 185,000 miles that is having frequent Engine Failsafe Mode issues. The car will basically need to be turned off for a few minutes then runs fine for another several days or even weeks. It happens at all times of the day or night and the error also says something about Traction Control Unavailable. The error code is P0430 and I was told by my mechanic that it is probably the oxygen sensors but another person told me it was most likely the Catalytic Converter.
Any ideas??? Thank you
Old Apr 1, 2012 | 11:22 AM
JaguarXJR02's Avatar
there a lots of things that can cause the failsafe mode issue. on my car it was a problem throttle body unit. There are lots of threads on here about the failsafe mode problem
there are a few good threads in here:
https://www.jaguarforums.com/forum/x...k-links-20090/
good luck
Drew2006
Nov 24, 2015 11:14 AM
JakeJagg11
Sep 3, 2015 07:36 PM
lee,lee
Aug 31, 2015 04:35 PM
kesslari
Aug 31, 2015 04:53 AM
roumor
Aug 28, 2015 01:02 PM
