XJR intake air temp sensor
I am getting code P1111, which is intake air temp sensor intermittent high voltage.
So my question is, does anyone know where this is on an XJR?
Thanks for the info. I was a bit confused as I found this site which listed P1111 as a sensor problem.
Jaguar Check Engine Light DTC Trouble Codes
Well I guess this is good news! My only problem is the EGR valve (throwing P0400 as well)
