XJR Tranny Service
Old Apr 5, 2018 | 08:49 AM
Car Crazy's Avatar
Default XJR Tranny Service
I have a 2002 XJR with the Mercedes 722.6 transmission, does the connector and connector plate need to be changed out when doing a full fluid change ??
Old Apr 5, 2018 | 11:00 AM
hispeed42's Avatar
Default Maybe ...
Here's the TSB so that you can check the connector while you're under there:
Mark
2002 XJR-100
File Type: pdf
Old Apr 5, 2018 | 12:19 PM
RJ237's Avatar
If the connector isn't leaking and there has not been a transmission fault I would just change the filter and fluid. Those are fairly common problems but are not universal.
Lagonia
20
Nov 21, 2015 04:02 PM
bkrdoug
Sep 26, 2012 07:22 PM
TheSeeker
Nov 18, 2010 11:22 AM
benebob
Jul 23, 2010 03:40 PM
Jack Rabbit
Aug 12, 2007 12:30 PM
