XJR transmission oil
Old Apr 20, 2017 | 05:19 PM
maniqz's Avatar
Default XJR transmission oil
Hi can someone give me the right transmission oil for my 2002 XJR? I need to do a trans oil change, thanks.
Old Apr 20, 2017 | 05:55 PM
Vector's Avatar
Shell ATF 134 is what I use, but there are others.
Ryder Fleet Products online usually has the best deals.
Vector
Old Apr 20, 2017 | 08:56 PM
JBzXJ40's Avatar
Yours has a Mercedes Benz transmission, so if you want genuine, you'll need to source it from a MB dealer, but I'm sure there are other fluids out there that can perform the same.
Old Apr 21, 2017 | 08:42 AM
Finn's Avatar
For my 2000 XJR local official Mercedes service told me it requires 236.14 fluid. And that is what I got ie. Fuchs TITAN ATF 4134.
I don't know if your 2002 requires the same but here is Mercedes 236.14 approved fluis list:
https://bevo.mercedes-benz.com/bevol...236.14_en.html
Old Apr 22, 2017 | 03:58 PM
Sean B's Avatar
Fin - is the Fuchs titan cherry red like the Merc stuff?
Old Apr 23, 2017 | 01:16 AM
Finn's Avatar
Yes, that is a good desription for it's color. To my understanding all 236.14 oils have same color.
This is what the old one looked like.
Old Apr 23, 2017 | 03:04 PM
Shotimer's Avatar
Valvoline Maxlife ATF works well.
AMSoil Universal ATF works well also.
A filter change, pan gasket, and electronic plug seal would be a good idea.
