XJR Transmission Removal & Install extract from JTIS21 FAQ
Old Jul 12, 2011 | 12:09 PM
jimlombardi's Avatar
Default XJ Transmission Removal & Install extract from JTIS21 FAQ
Hi
I extracted these Transmission Removal & Install instructions & illustrations from the JTIS21 Shop Repair Manual back in Oct 2010 when our 2001 XJ8 needed a new forward drum replacement. We decided to have the transmission completed rebuilt.
I give our Indy mechanic a printout of these 2 PDF files that I created to use for the removal & reinstall for XJ (except XJR):
XJ8 ZF 5HP24 Transmission removal 44.20.01.pdf
XJ8 ZF 5HP24 Transmission installation 44.20.01.pdf
The XJR has the Mercedes Transmission removal & install are a little different than the XJ8.
Here are the PDF files for the XJR W5A580 Transmission Removal & Install:
XJR W5A580 Transmission removal 44.20.01.pdf
XJR W5A580 Transmission Installation 44.20.01.pdf
Jim Lombardi
Old Jul 13, 2011 | 02:37 AM
Cadillac's Avatar
Thanks , will FAQ
Old Feb 18, 2015 | 11:18 AM
dolamyte's Avatar
is it hard to put the merc transmission in an xj, or is it not even possible?
Old Feb 18, 2015 | 06:23 PM
wesmc2's Avatar
For a tranny swap it isn't a bad job....I find getting the exhaust on and off the biggest pita.
Old Feb 18, 2015 | 06:26 PM
wesmc2's Avatar
Oh...I misunderstood your question. Do you mean swapping from the ZF 5HP box to a Merc box for a supercharged car? I have no idea how to do that.
Forcedair1
Sep 8, 2025 01:57 PM
davidladewig
Sep 3, 2015 06:32 PM
Dallas XK8
Sep 3, 2015 12:17 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
